Article ID : 00247435 / Last Modified : 24/11/2021
What type of content (movies, games, platform or apps) is compatible with 21:9 aspect ratio?
    Valid for
    • Xperia 1 II
    • Xperia 10 II
    • Xperia L4
    • Xperia 1
    • Xperia 5
    • Xperia 10
    • Xperia 10 Plus
    Solution
    Below is the compatibility criteria to see the content e. g. Applications, Movies, Games, Platform in 21:9 aspect ratio.
    1. The compatibility begins with applications fitted to 21:9 screen.  As per the guidance from Google, all applications released on Google Platform must support 21:9 aspect ratio.
    2. The content created begins to support 21:9, 16:9 aspect ratio. Major service providers such as Netflix, Amazon Prime and YouTube already have a lot of 21:9 compatible contents available. Depending on the application, even if you play 16:9 contents, you can zoom-in to fit into 21:9 screen.
