Article ID : 00247786 / Last Modified : 20/01/2026Print
    Do all Android 10 Xperia products support DUALSHOCK 4 in PS4 Remote Play app?
    Valid For
    • Xperia 10  (with Android 10)
    • Xperia 10 Plus  (with Android 10)
    • Xperia 10 II
    Solution
    With PS4 Remote Play ver. 7.0 or later app, also Xperia value-line devices*1  are available to install from the Google Play store.
    With Android 10, you can use your DUALSHOCKTM 4 controller in PS4 Remote Play. However, some functions on the DUALSHOCKTM 4 controller such as the touch pad, colour of the light bar, rumble, motion sensor and headphone jack audio connection, are not available.
    *1: PS4 Remote Play ver. 7.0 or later app requires Android 5.0 or higher.
    Note1: Sony mobile doesn't guarantee that PS4 Remote Play app and DUALSHOCKTM 4 may work on all of Xperia value line devices if they meet the requirements.
    Note2: Xperia premium models, for example, Xperia 1, Xperia 5, Xperia XZ3, Xperia XZ2, Xperia XZ2 Compact, Xperia XZ2 Premium, and Xperia XZ3 are compatible with PS4 Remote Play app and DUALSHOCKTM 4 controller.  For more information, please refer to the following article; How do I set up an Xperia device and a PS4 for Remote Play?
