Article ID : 00238583 / Last Modified : 20/01/2026Print
    Unable to connect to the Music Center app when playing music from a USB device.
    If your car audio player is connected to a USB device and playing music from that source, it may then fail when you try to connect and play music via a Bluetooth® connection from the Music Center app on a smartphone.
    If this is the case, stop playing from the USB audio source first, then connect the Music Center app to the car audio.
