My smartphone battery drains quickly - how to optimise your Xperia battery consumption
Understanding battery health and performance
Have you noticed how often new smartphone models are thinner than their predecessors? Much of this has only been possible due to advancements in battery technology over the years.
Good things come in small packages
Traditionally, batteries were large in size. The bigger the battery, the higher the capacity. Lithium-ion batteries on the other hand are smaller in size, but pack a larger capacity than traditional batteries. Battery capacity is measured in milliamp-hours (mAh). Some lithium-ion powered smartphones have a capacity of up to 4000 mAh compared to non-lithium-ion powered phones with capacities up to 950 mAh.
Reduced battery size also means more space and opportunity to add new components. For instance, the extra cameras on some newer phones, or space to add a second SIM card. Together with the power and spacial increases, your Xperia smartphone utilises the latest in lithium-ion technology to deliver improved battery life, faster charging and enhanced durability.
Old isn't always gold
All rechargeable batteries chemically age. The longer a battery is used or the older it gets, over time the performance can be expected to reduce. This means that as your battery ages, the amount of charge your device holds will reduce. Proactive upkeep will ensure a longer-lasting battery.
Newer models running Android 8 or above utilise Battery Care as an added feature to protect your battery when charging. When enabled, your phone will begin to recognise your charging behaviour and optimise when the battery is charged to 100%. E.g. If you wake up every day at around 8.30 am, and plug in your phone to charge overnight. The speed at which the battery is charged will be slowed down in order to reach 100% charge by 8.30 am. This charging method is highly effective to prevent overcharging.
Battery care: the 4 do's and don'ts
- Use the original charger that came with your Xperia device.
- Limit exposing your device to extremely hot (37°C or above/direct sunlight) or cold environments (temperatures below 0°C).
- Charge your device just as much as needed. If you leave your device charging for a long time after reaching 100%, it might reduce battery performance (applicable if you do not have Battery Care feature).
- If you plan to store your device for an extended period, charge it between 20 - 80% and then turn it off (Tip: this applies to any device with a rechargeable battery).
Tips to improve Xperia battery life
It is important to understand that the effectiveness of these tips will vary based on the chemical age of your battery.
Important: Some of these tips may not be applicable to all Android versions.
1. Turn on the battery and power-saving features
- Turn on and set up STAMINA mode.
- Activate Ultra STAMINA mode.
- Activate Battery Care (Applicable to devices running Android 8 and above).
Detailed instructions
To turn on STAMINA mode
- Find and tap Settings → Battery → STAMINA mode.
- Tap Always on to activate STAMINA mode right away or tap Auto start at 15% battery to let STAMINA mode activate at a battery level between 15 and 95%. To set the activation level, tap the Gear icon.
To activate Ultra STAMINA mode
- Find and tap Settings → Battery → Ultra STAMINA mode.
- Tap ACTIVATE.
To turn on Battery Care (Android 8.0 & up)
- Find and tap Settings → Battery → Battery Care.
- Tap the switch beside Off to turn the feature on.
2. Optimise your settings to use less battery
- Reduce the brightness level of the screen.
- Turn on Adaptive brightness to optimise brightness level for the available light.
- Set a shorter sleep time before your screen turns off.
- Turn off Dialpad tones and sounds for screen-locking and touch.
- Turn off sounds and vibrations for the on-screen keyboard.
- Turn off automatic app updates.
To reduce the brightness level of the screen
- Find and tap Settings → Display → Brightness level.
- Drag the slider to reduce the brightness level.
To turn on Adaptive brightness
- Find and tap Settings → Display → Adaptive brightness.
- Tap the switch beside Adaptive brightness to turn the feature on.
To set the display sleep time
- Find and tap Settings → Display → Sleep.
- Select a sleep time.
To turn off Dialpad tones, and sounds for screen-locking and touch
- Find and tap Settings → Sound & notification → Other sounds.
- Tap the switch beside Dialpad tones to turn the feature off.
- Tap the switch beside Screen locking sounds to turn the feature off.
- Tap the switch beside Touch sounds to turn the feature off.
To turn off sounds and vibrations for the on-screen keyboard
- Find and tap Settings → Language & input → Xperia™ keyboard → Keypress feedback.
- Tap the switch beside Sound on keypress to turn the feature off.
- Tap the switch beside Vibration on keypress to turn the feature off.
To turn off automatic app updates
- Find and tap the Play Store app from your apps screen.
- Slide your finger right starting from the left side of the screen.
- Tap Settings → Auto-update apps → Over Wi-Fi only / Don't auto-update apps → Done.
3. Turn off connectivity and location services
- Turn off Bluetooth® when you’re not using it.
- Turn off Wi-Fi to prevent your device from using the battery when trying to stay connected in weak coverage situations.
- Turn on Airplane mode to prevent your device from using the battery when trying to stay connected in weak coverage situations. It is also especially useful when you are using your phone but do not require Wi-Fi or data e.g. viewing your albums or when you listen to downloaded music.
To turn off Wi-Fi
- Find and tap Settings → Wi-Fi.
- Tap the switch beside On to turn it off.
To turn off Bluetooth
- Find and tap Settings → Bluetooth.
- Tap the switch beside On to turn the feature off.
To turn on Airplane mode
- Find and tap Settings → More.
- Tap the switch beside Airplane mode to turn the feature on.
4. Avoid or limit high drain activities
High-performance activities might drain your battery more quickly. Examples of high battery consuming activities are:
- Using GPS or showing navigation for long periods.
- Streaming and watching videos and music.
- Playing highly interactive or graphics-heavy games.
- Tethering (“hotspots”).
- Phone calls when you are on the move (like in a car).
- Heavy camera use.
- Using apps for long periods.
- NFC (Near Field Communication) ON when it is not needed.
To turn off NFC (Near Field Communication)
- Find and tap Settings → Device connection → Connection preferences.
- Tap the switch beside NFC to turn it OFF
[Optional] Identify which app or setting is consuming your battery the most
If you have tried the tips above and your battery is still not holding a charge, try to identify whether an app is causing the issue. The process varies across Android versions. Check which Android version your phone is running if you are unsure. If you identify a particular app to be the issue, try changing how you use the app. E.g. YouTube is often a high battery drain activity. If this is the case your battery may not necessarily be affected. Try watching your videos with less brightness. Also, use your earphones or headphones instead of the phone speaker to save battery life.
Android 10
- Find and tap Settings → Battery to view the estimated remaining battery percentage and battery time.
- Tap (More icon) → Battery usage to view a list of applications and features that have consumed battery power since the last charging cycle. Tap (More icon) to switch between app usage and full device usage.
- Tap an item to get information on how to reduce its battery consumption.
Android 8, 9
- Tap Advanced to view a list of applications and features that have consumed battery power since the last charging cycle.
