Article ID : 00231111 / Last Modified : 30/07/2019
Can I do sports with the WF-1000XM3 Noise Cancelling Truly Wireless Earbuds?
    The WF-1000XM3 is not waterproof. If water or foreign objects (e.g. dust) enter your product, it may cause damage, fire or electric shock. If that happens, stop use immediately and consult your nearest Sony dealer.
    In particular, be careful when:
    • using the product around a sink. Be mindful that the unit does not fall into a sink or container filled with water.
    • using the product in the rain or snow, or humid/wet locations.
    • using the unit while you are sweaty. If you touch the earbuds with wet hands or put the unit in the pocket of a damp article of clothing, it may get wet.
    Find more information on headphones IP ratings
