Article ID : 00231411 / Last Modified : 02/12/2019
RAW images recorded using the following models have a resolution of 14 bits per pixel. However, resolution is limited to 12 bits under certain shooting conditions.
    ILCE-7 / ILCE-7R / DSC-RX1 / DSC-RX1R
     Single-shot shooting *1Continuous shooting *2BULB shootingLong Exposure NR is activated *3
    Compressed RAW14 bits12 bits12 bits12 bits
    ILCE-7M2 / ILCA-99M2 / DSC-RX1RM2
    Uncompressed RAW14 bits12 bits12 bits12 bits
    ILCE-7S / ILCE-6100 / ILCE-6300 / ILCE-6400 / ILCE-6500 / ILCE-6600
    • Silent Shooting: Off
    • Silent Shooting: On
      Compressed RAW12 bits12 bits
    ILCE-7RM2 / ILCE-7SM2
      Uncompressed RAW12 bits12 bits
    ILCE-7RM3 / ILCE-7M3/ ILCE-7RM4
      Uncompressed RAW14 bits14 bits12 bits12 bits
    ILCE-9
    • Shutter Type: Mechanical Shut
    • Shutter Type: Electronic Shut
    ILCE-9M2
    *1 “Single-shot shooting”, described above, includes self-timer shooting and interval shooting.
    *2 “Continuous shooting”, described above, includes multiple burst shooting under Superior Auto mode, continuous shooting under self-timer mode and continuous bracket shooting.
    *3 Long Exposure NR is active when it is set to On and the shutter speed is set to 1 second or longer.
    NOTE: JPEG images will be recorded in 8 bits.
