Article ID : 00226907 / Last Modified : 28/11/2022Print
My Amazon Alexa - Sorry, the device is offline - doesn't recognise the Sound bar
    Check the following if your Amazon Alexa™ device says "Sorry, the device is offline" when you try to stream music to your Sound bar:
    • Check if your soundbar is connected to the internet.
      • Select SetupSetup > Advanced Settings > Network Settings > Network Connection Status.
    • If Network/Bluetooth Standby is Off, set it to On.
      • Select SetupSetup > Advanced Settings > System Settings > Network/Bluetooth Standby > On.
    • Perform a power reset.
      • Turn off the soundbar.
      • Unplug the power cord from the AC wall outlet and then wait for one minute.
      • Plug in the power cord again and then turn on the soundbar.
