Benefits & features of the ILCE-9 Firmware Update to Ver.5.00
The system software (firmware) update to Ver.5.00 expands on the model’s already acclaimed AF performance and adds a host of new functions that further support shooting, viewing and customising the camera.
NOTE: For the latest system software (firmware) update, check ILCE-9 Downloads section.
IMPORTANT: Please review the following benefits and changes before performing the update.
Added functions and changes to specifications
Check the changes described below prior to installing the update. When links to the Help Guide or other information are provided, also refer to that information.
- Highly accurate automatic detection and tracking of subjects / Tracking, Tracking On, Touch Tracking
A subject tracking function has been provided that improves the conventional Lock-on AF function. A newly developed object recognition algorithm achieves real-time high-speed processing of spatial information consisting of color, pattern (brightness level), and subject distance (depth). In addition to the conventional operation method of setting the focus area mode to Tracking, you can also start tracking at the desired time by assigning Tracking On to theCustom Key. Furthermore, setting Touch Tracking from the menu lets you select the subject to be tracked by simply touching the desired subject on the monitor. Tracking and Tracking On are available in still image shooting mode. Touch Tracking is available in still image shooting mode and movie shooting mode, but unavailable when shooting with the viewfinder.
- Evolution of Eye AF function / Face/Eye AF Set.
A Face/Eye AF Set. function evolved from the conventional Face detection function has been provided. The function has been enhanced so that Eye AF (AF-C/AF-S mode support) operates even while the shutter button is pressed halfway down or the AF-ON button is pressed. In addition, you can have the camera automatically select the eye on which to focus, or you can specify the right eye or left eye beforehand. Eye AF is not available during movie shooting. - Touch pad function / Touch Pad Settings
A touch pad function has been provided that lets you move the focusing frame position by dragging your finger on the monitor like a touch pad. The focusing position moves in accordance with the amount of movement of your finger on the monitor. This lets you move the focusing position smoothly while looking through the viewfinder. In addition, a setting that moves the focusing position to the position where the monitor is touched is also available. - Increased focal plane phase detection AF accuracy and expanded application range
The AF algorithm has been further brushed-up to improve the focal plane phase detection AF accuracy during AF-C and continuous shooting. Performance has also been enhanced in environments with lower light compared to outdoors, such as indoor sports scenes. In addition, the aperture value range over which focal plane phase detection AF is available during AF-C and continuous shooting has been expanded. The maximum value has been increased from the conventional F11 to F16. This expands the AF application range to enable use such as panning during continuous shooting. This is supported when any E-mount lens that supports focal plane phase detection AF is mounted. - Increased number of contrast AF frame divisions
The number of contrast AF frame divisions has been increased from the current 25 points to 425 points. This enables highly accurate AF even in low-light environments or other scenes where contrast AF is advantageous. Use in combination with 693-point focal plane phase detection AF realizes high-speed, highly accurate AF in all circumstances. - Circulate focusing position setting / Circ. of Focus Point
A new setting has been added that lets you circulate the focusing position to the up, down, left and right sides. This lets you efficiently set the focusing position when the subject moves frequently from one end to the other of the AF area, such as when shooting sports scenes. - Display only frequently used focus area types / Focus Area Limit
A function has been added that displays only the focus area types frequently used by the user when setting the AF area. This limited display is also reflected when Switch Focus Area is assigned to a custom button. - Limited ISO display / ISO Setting: ISO Range Limit
You can set the camera so that only frequently used ISO ranges are displayed in the ISO setting screen. This lets you change the setting more quickly in shooting mode. - Display ISO value all the time when recording movies in ISO AUTO mode
A function has been added that lets you display the ISO value all the time when recording movies in ISO AUTO mode. This lets you record while checking the ISO value, even when recording in dark surroundings where the noise level is a concern. - Simpler white balance setting / White Balance
The white balance color temperature setting has been simplified. In addition, the number of setting steps has been reduced and operability has been enhanced during custom white balance operation. - AWB lock function /
Shutter AWB Lock, AWB Lock Hold, AWB Lock Toggle
You can select whether or not to lock the auto white balance at the desired timing. This is convenient when you want to lock the auto white balance in an environment with multiple light sources such as artificial light and natural light. You can also lock the white balance in the auto white balance mode by assigning AWB Lock Hold or AWB Lock Toggle to a custom key. - Increased detection accuracy of peaking function and addition of blue peaking color / Peaking Setting
The detection accuracy of the peaking function that enhances the outline of in-focus areas with the specified color has been increased. This makes it even easier to understand the focus peak during macro shooting and portrait shooting that require precise focusing. In addition, blue has been newly added to the available peaking colors (red, yellow, white). Selecting the blue peaking color, which is a colder color, for warmer colored subjects helps increase visibility when focusing on various subjects. - Addition of initial magnification settings for focus magnifier in movie recording mode /
Initial Focus Mag.
You can set the initial magnification for focus magnifier in movie recording mode. The initial magnification can be selected from x1 or x4. - JPEG picture quality setting in RAW & JPEG recording mode /
File Format,
JPEG Quality
You can select the JPEG picture quality from among Extra fine, Fine or Standard when the still image recording file format is set to RAW & JPEG. - Support for monitor off in shooting mode / Monitor Off
Monitor Off has been added to the screen display modes that can be selected by the DISP button (Display Setting) in shooting mode. When set to Monitor Off, the monitor turns off other than when playing back images or performing MENU operations. This is convenient when shooting starry skies or other scenes in dark surroundings where the monitor brightness is a concern. - Support for simultaneous recording of proxy movies /
Proxy Recording
Simultaneous recording of 4K movies and low definition proxy movies is supported. The load on the computer can be reduced and work efficiency increased when editing 4K movies by using proxy movies with a small file size for editing and previews. - Support for 1:1 image aspect ratio /
Aspect Ratio
The 1:1 image aspect ratio is supported in addition to the conventional 3:2 and 16:9 aspect ratios. This enables shooting with a preset aspect ratio and composition optimized for posting to SNS, etc. - Metering based on faces / Face Priority in Multi Metering
The camera can measure brightness based on detected faces when Metering Mode is set to Multi. - Zebra function setting method / Zebra Setting
Zebra display and zebra level can be set separately. - Support for exposure compensation while pressing the shutter button halfway down in still image shooting mode
Exposure compensation can be performed by operating the exposure compensation dial while pressing the shutter button halfway down in auto focus mode. - Addition of movie recording format XAVC S HD recording settings
60p 25M and 30p 16M have been added to Record Setting.
- Rating function / Rating
You can set ratings in five levels (-
) for recorded still images on the camera. Ratings set on the camera are carried over to applications such as PlayMemories Home and Imaging Edge (Viewer) even after the images are imported to your computer. In addition, you can also assign ratings on the playback screen by assigning the rating function to a custom key.
- Protect function / Protect
The protect function that protects recorded images against accidental erasure can now be used quickly on the playback screen by using a custom key (assigned to the C3 button in the default settings). Rating and Protect on the playback screen are useful for selection work during idle time such as at shooting sites or while travelling. - Group display of continuous shooting images / Display as Group
You can display recorded images by continuous shooting group. This makes the image index screen list easier to view during playback. You can also delete, protect or transfer images to a smartphone in continuous shooting group units. - Support for jumping between images during playback / Image Jump Setting
You can set the dial and method to use for jumping between images during playback. This lets you more easily find protected images or images set with a particular rating.
- Advanced dual slot functionality / Auto Switch Media
You can set the camera to automatically switch the recording destination to the other slot when the memory card in use becomes full and images can no longer be recorded to that memory card while shooting still images or recording movies. In addition, you can select from Sort(JPEG/RAW) or Sort(RAW/JPEG) as the method of recording still images separately to two memory cards. - Changing the function of the dial temporarily / My Dial Settings
You can assign desired functions to the front dial, rear dial and control wheel, and register up to three combinations of settings as “My Dial”. You can quickly recall or switch registered “My Dial” settings by pressing the custom key you assigned in advance. - Assigning functions to custom keys / custom key
You can select and assign desired functions from among up to 112 different options to custom keys. This lets you separately assign different functions for still image shooting mode, movie recording mode, and playback mode. In addition, an illustration showing the camera operation parts has been added to the custom key setting screen. This lets you check which buttons and switches to assign functions to at a glance. - Improved usability of function menu settings / Function Menu Set.
Usability has been improved, such as by enabling to make function menu settings while viewing the actual function menu configuration. - Selection of memory card slot for Memory recall (MR) function that enables to quickly recall camera settings /
Select Media
You can select the memory card from which settings are recalled by the Memory recall (MR) function from slot 1 or slot 2. This lets you register different settings to multiple memory cards. - Front dial/rear dial with changeable direction of rotation / Av/Tv Rotate
You can change the direction of rotation for the front dial and rear dial from the menu in accordance with your preference.
- Support for Imaging Edge Mobile
The system software supports Imaging Edge Mobile, which is the successor application to PlayMemories Mobile. This enables remote control of the camera using a smartphone, and automatic transfer of images to the smartphone while recording. Note that PlayMemories Mobile must be updated to Imaging Edge Mobile. - Support for wired LAN remote control
You can remotely control the camera with a high degree of freedom suited to professional sites via the PC app “Remote Camera Tool”. You can also remotely control an Ethernet connected camera or multiple cameras from this application. In addition, remote control is possible even during FTP transfer, which achieves even higher shooting efficiency. - Support for smartphone always connected / Ctrl w/ Smartphone
You can set whether or not to always connect the camera to a smartphone. When this function is set to On, once you connect the camera to a smartphone, it will remain connected to the smartphone at all times.
Deleted functions
Check the deleted functions described below prior to installing the update. When links to the Help Guide or other information are provided, also refer to that information.
- Changes to movie recording format and recording settings /
File Format,
Record Setting
60p 25M and 30p 16M have been added to theRecord Setting of XAVC S HD. The following specifications have been changed accordingly.
- The recording format MP4 has been deleted. Accordingly, Folder View (MP4), which displays only MP4 movies in playback mode, has also been deleted.
- 60p 28M(PS), 24p 17M(FH) and 24p 24M(FX) have been deleted from theRecord Setting of AVCHD movies. To continue recording AVCHD movies, use 60i 24M(FX) or 60i 17M(FH).
- Simultaneous video recording function / Dual Video REC
A function has been added that simultaneously records low definition proxy movies when recording XAVC S movies. Accordingly, Dual Video REC, which simultaneously records MP4 movies when recording XAVC S movies or AVCHD movies, has been deleted.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
