Check points before installing Updates for your Sony VAIO computer
Check the following before installing the latest update or driver for your VAIO® computer:
- The steps are different on each update program. Make sure to follow the instructions carefully in the Drivers & Software section
- Make sure to check the file size of the downloaded update
- Make sure that there's no suspicious file in the folder where you save the downloaded update
