Sony Global - Support by Sony - OPEN SOURCE COMPONENTS in "Support by Sony" Application
Never Miss an Update with Support by Sony
The Support by Sony app allows you to access various support information about your Sony products. Get the most out of your product by receiving firmware update notifications, and viewing various support materials including manuals and Q&A. Bookmark your Sony product to the Support by Sony app and never miss an update again.
Watch Video
Download Support by Sony
Get started in seconds
Search for your Sony product and add it to your app
  • 1Search for your product.
  • 2Tap [Add] to bookmark.
  • 3Quickly find support information.
Find Various Support Information Instantly
Bookmark your Sony product to the app and you can quickly find support information to troubleshoot your product. Tap your product and you will see the support page with information including Q&A, manuals and more.
Get Update Notifications
Once you bookmark a Sony product, you will receive important information, and notifications of the latest firmware updates.
Bookmark your Sony product by NFC
Android smartphones only
If your Sony product and smartphone are equipped with an NFC function, first start "Support by Sony" and then touch your smartphone to the NFC symbol of your Sony product, and the support page will be displayed instantly, where you can add the product to your app with one tap without searching.
