Use Memory and Memory Recall on a Camera
Use Memory and Memory Recall to save and load your frequently used settings on your camera.
What Settings Can You Save?
- Shooting Mode
- Aperture and/or shutter speed
- Settings in the
tab (There are some options that cannot be saved.)
Save Your Settings to Memory
- Select a shooting mode such as M, S, A, P, Auto, SCN, S&Q,
(Panorama), or
(Movie).
- Set up your camera with the settings you want to save.
- Press the MENU button.
- On the
tab, select Memory.
- Press the left and right buttons to select your save location.
- 1, 2, or 3 for your camera's internal memory.
- M1, M2, M3, or M4 for the memory card.
- Press the center button.
Recall Your Saved Settings
Follow the steps depending on the location where you saved your settings:
- 1, 2, or 3
- Turn the mode dial to either MR, 1, 2, or 3.
- The modes on your camera vary depending on your model. Check your manual for model-specific information.
- ILCE-6000
- ILCE-7
- ILCE-9
- ILCE-6000
- If your camera has MR mode, press the left or right button to select 1 or 2.
- M1, M2, M3, or M4
- Press the left or right buttons to highlight your saved location.
Other Information
- You can select Memory Recall or Recall from the menu to switch between settings in the memory card and the mode dial.
- Memory Recall or Recall is only active (not grayed out) if the mode dial is on MR, 1, 2, or 3.
- If you select Memory Recall or Recall, you can inspect the saved settings. To see all the settings, press the down button.
- Saved settings remain in memory even after you perform Camera Settings Reset.
- Selecting Initialize deletes settings in 1, 2, and 3.
- Formatting the memory card deletes settings in M1, M2, M3, and M4. You won't access the saved settings if you remove or replace the memory card.
