What Soundbars are supported by the A/V Sync setting on my Android TV?
List of specific audio systems that are supported by the A/V sync setting
A/V sync-compatible Soundbars
The A/V sync setting on your Sony Android TV supports the following Soundbars via HDMI (when the A/V sync setting is set to Auto):
- HT-Z9F
- HT-ZF9
- HT-X9000F
- HT-XF9000
- HT-X8500
- HT-G700
How to set A/V Sync to Auto
You can change the A/V Sync mode to Auto by following the steps below:
- Press the HOME button on the remote control.
- Select the
Settings icon.
- This step will vary depending on the options available in your TV menu. Follow the steps accordingly:
- Select Display & Sound → Audio output → A/V sync → Auto.
- Select Sound → A/V sync → Auto.
