Article ID : 00183799 / Last Modified : 30/03/2018Print
    Headphones won't charge with third-party USB cables
    You might encounter difficulties charging your headphones using a third-party USB cable.
    There are USB cables available which are being promoted as "For Charging Only". These cables have a reduced internal connection pattern, in which the D+/- communication wires are not connected.
    For Bluetooth and noise-cancelling headphones, but also for most other Sony portable products, it is important that these communication lines are connected. If they are not connected, charging your device may become impossible or problematic.
    In case your cable needs replacing, make sure that you purchase an original Sony cable at a Sony Authorised Centre, or that the cable is a "fully connected" standard USB cable.
