How to transfer music to a Walkman using a computer
This page explains how to transfer music to a Walkman. Select either Windows or Mac, depending on your personal set-up.
IMPORTANT: There may be different software applications and transfer methods available, depending on the Walkman model. Manuals are posted on your model support page.
Using Sony software to transfer the music to your Walkman
Manage the music using Sony software and transfer it to your Walkman device.
Music Center for PC (Windows) | |
Content Transfer (Mac) |
Attention: Support for the Media Go software had ended. For a Windows computer, use the Music Center for PC software. which is the successor to the Media Go software. For Music Center for PC software compatible device information, refer to the Music Center for PC — Supported Devices web page.
