Article ID : 00176933 / Last Modified : 08/02/2019
Why is the Equaliser setting under the Sound menu grayed out?
    The Equaliser setting is grayed out in the conditions below:
    • Sound Mode is set to Music, Cinema, or Sports
    • Sound restoration (DSEE) is set to Auto.
    • Surround is set to Auto or On.
    In order to customize the Equaliser setting, do the following:
    1. Set Sound Mode to Standard.
    2. Set Surround to Off.
    3. Set Sound Restoration (DSEE) to Off.
    NOTE:When Equaliser is grayed out, Equaliser will be adjusted to recommended sound quality.
