Frequently Asked Questions about the Assistant function of the In-car Bluetooth Commander
Why doesn't Assistant start on my In-car Bluetooth Commander?
Where does Assistant receive its information from?
How do I change the volume of Assistant’s responses?
Below is a table of FAQs about the Assistant function of the In-Car Bluetooth® Commander.
Questions | Answers |
How to speak to the In-car Bluetooth Commander. | To speak to the In-car Bluetooth Commander, follow the steps below.
How to stop dialogue? |
On the In-car Bluetooth Commander, press the VOICE button. NOTE: You can also stop the dialogue with Assistant by saying Cancel when prompted to speak. |
How to change the volume of Assistant’s responses? | When Assistant is speaking, push the Volume button on your smartphone or turn the bezel on the In-car Bluetooth Commander to change the volume. |
Why doesn't Assistant start on the In-car Bluetooth Commander? | When Assistant does not start on the In-car Bluetooth Commander, check the following.
If you still have problems after trying these solutions suggested above, check the specifications or supplied operations guide for more information. |
Where does Assistant receive its information from? |
The following are the information sources for each function:
NOTE: For more information and operation method, visit the Assistant webpage.
