Frequently Asked Questions (FAQs) about the PS-HX500
Below are the tables of frequently asked questions about the PS-HX500.
Question |
Answer |
Can the PS-HX500 playback 78 rpm records? | No, the PS-HX500 only supports 33 rpm and 45 rpm records. |
Can audio tracks be played back by connecting the unit and a computer via USB? | No, the USB port on the unit is only for recording audio tracks onto a computer via the Hi-Res Audio Recorder application. |
How do you record a Hi-Res audio source with this unit and play it as Hi-Res audio on a Walkman? |
Transfer the audio source to a Walkman by following these steps:
Question |
Answer |
What file formats (audio output data file) are compatible with recording? |
The following are the compatible file formats.
Can the file names be changed? | File names can be changed when files are exported onto a computer via the Hi-Res Audio Recorder application. To change the file name, follow the procedure below:
When recording audio tracks onto a computer via the Hi-Res Audio Recorder application, can audio tracks be recorded in various file formats simultaneously? | No, audio tracks cannot be recorded in various file formats simultaneously. | ||||||
Can audio tracks recorded onto a computer via the Hi-Res Audio Recorder application be edited? | The Hi-Res Audio Recorder application is a recording application and recorded audio tracks cannot be edited with this application. To edit recorded audio tracks, use another application. We recommend Media Go™ for editing. | ||||||
When downloading data to a PC using the Hi-Res Audio Recorder, are track information and album information written as metadata? | The track title and the artist information edited by Hi-Res Audio Recorder are written as metadata. The information is stored in different places depending on its format.
You can display the information using a playback device or a playback application compatible with these data. |
Is sound output from a PC while recording in Hi-Res Audio quality? | No, it is not. To ensure the recording, a PC converts files to playable audio file formats and outputs sound separately from storing data. | ||||||
Is it possible to record files using applications other than Hi-Res Audio Recorder? | Hi-Res Audio Recorder is the only supported application for recording. | ||||||
The Hi-Res Audio Recorder application cannot be installed onto a Windows® computer. An error message about a digital signature appears when the unit is connected to a computer and the unit is not recognised correctly by the computer. | The Hi-Res Audio Recorder application may not be installed correctly if your computer does not have the latest version of Windows. Run Windows Update to update your computer to the latest version, then install the application. | ||||||
I cannot adjust the recording level on the Hi-Res Audio Recorder. | The latest version of the Hi-Res Audio Recorder allows you to adjust the recording level. Install the latest version on your computer.
If you are using the old version, the message on the latest version will appear when you start Hi-Res Audio Recorder. You can also download the latest version from here. https://www.sony.co.uk/support/en/product/PS-HX500 |
My computer or Hi-Res Audio Recorder do not detect the turntable when connected via USB | For details, please refer to the following FAQ: My computer or Hi-Res Audio Recorder do not detect the turntable when connected via USB |
Question |
Answer |
How can I replace the original stylus with a new one? | Use a stylus that is exclusively designed for this unit. Other styluses are not supported. To obtain a spare stylus, contact your dealer or the customer support website. |
Can I replace the cartridge with the one that is not the same type as the originally installed? | This unit is tuned according to the originally installed cartridge. Replacing with other types of cartridges is not supported. |
What are the precautions when sending the unit for repair, etc.? | Sending the unit in an assembled state may cause breakages or malfunctions. Disassemble the parts and pack them securely when you send the unit.
