Article ID : 00147074 / Last Modified : 14/04/2016
How to record programmes on your TV (WD6 and RD4 Series)
Here is a short guide on how to record programmes on your TV.
NOTE: This article relates to the following series:
  • WD6 Series: KDL-32WD603, KDL-32WD605, KDL-32WD600 | KDL-40WD653, KDL-40WD655, KDL-40WD650 | KDL-48WD653, KDL-48WD655, KDL-48WD650
  • RD4 Series: KDL-32RD433, KDL-32RD435, KDL-32RD430 | KDL-40RD453, KDL-40RD455, KDL-40RD450
  1. Press HOME in digital mode
  2. Press the up/down arrow buttons, then the plus button to select [Recordings]
  3. Press the up/down arrow buttons, then the plus button to select [Title List] > [Error List] or [Manual Timer REC]
NOTES:
  • Press the REC button to record currently viewed programmes in digital mode with the USB HDD recording function.
  • Make sure you connect the HDD to the TV before recording.
  • HDD recording is not available on Italian 2K TVs (2016 models).
