Article ID : 00142391 / Last Modified : 16/01/2026Print
    Can cables be connected to the rear terminals when the TV is mounted on the wall?
    When the Android TV is mounted to the wall using the supplied wall-mount bracket, there will be very little space between the TV and the wall as shown in the image below.
    NOTES:
    • When the optional Wall-Mount Bracket (SU-WL450) is attached to the TV without the Wall-Mount Attachment, some terminals on the rear of the TV may not be accessible. Refer to the manual of the TV about which terminal is inaccessible.
    • For the X90xxC, X91xxC, and W95xC: When the TV is mounted to the wall using the supplied wall-mount bracket, the space between the TV and the wall [A] is inaccessible. Therefore, cables cannot be connected to the Rear Terminal [C] on the rear of the TV.
    space between wall and wall-mount bracket
    • [A] Space between TV and wall
    • [B] Wall
    Cables that cannot be connected to the following terminals, which are located at the rear part of the TV:
    • LAN
    • DIGITAL AUDIO OUT (OPTICAL)
    • VIDEO IN 1
    • VIDEO IN 2 / COMPONENT IN
    Use the other terminals of the TV for the audio and video connection. To connect the TV to the Internet, use wireless connection instead of the wired LAN.
    TV rear-view diagram:
    X90xxC and X91xxC Series
    TV terminals
    W95xC Series
    • [C] Rear Terminal
