Article ID : 00167807 / Last Modified : 29/03/2019Print
How to access the Device Manager (Windows 10)
    There are five ways to access the Device Manager:
    • Method 1: Right-click the Start button or press the Windows Logo + X key combination on the keyboard and, from the list, click to select Device Manager.
    Context menu - Device Manager
    • Method 2: On the taskbar, in the Search field next to the Start button, type Device Manager and then press the Enter key.
      Search - Device Manager
    • Method 3:
      1. Click the start button icon (Start) button.
      2. In the Start Menu, click Settings.
        Start - Settings
      3. In the SETTINGS window, click Devices.
        Settings - Device Manager
      4. In the DEVICES screen, click Printers & scanners or Connected devices, and under the Related Settings category, click Device manager.
        DEVICES - Device Manager
    • Method 4:
      • Right-click the Start button or press the Windows Logo + X key combination on the keyboard and, from the list, click Control Panel.
        Start - Control Panel
      • In the Control Panel window, click Device Manager.
        Control Panel - Device Manager
    • Method 5: One really easy way to start the Device Manager in any version of Windows is from the Command Prompt. Just open the Command Prompt and type devmgmt.msc
