Article ID : 00202640 / Last Modified : 17/09/2018Print
What do the terms Resolution and Aspect Ratio mean for my television?
    Resolution and aspect ratio are terms used to describe the format and image you see on your television screen.  In a television, these two values are related and one affects the other.
    Resolution
    The resolution defines the number of pixels (dots) that make up the picture on your television. For any given screen size, the more dots in the picture, the higher the resolution and the higher the overall quality of the picture.
    TV resolution is often stated as the number of pixels or dots contained vertically in the picture. Each of these resolutions also has a name associated with it.
    TV Resolution Example
    [A] Resolution (# of vertical dots)
    Aspect Ratio
    Closely tied to resolution is the Aspect Ratio.  This is the ratio of width to height of the TV screen. Certain aspect ratios are designed to handle certain resolutions without any stretching or distortion of the picture and without any blank space around the picture.
    TV Aspect Ratio Example
    [A] Height
    [B]Width
    Common examples for TVs
     Resolution
     Description
     Aspect Ratio
    Width (in pixels)
     Height (in pixels)
    480i or 480p
     Standard Definition (SD)
    4:3
    640
    480
    720p
     High Definition (HD)
    16:9
    1280
    720
    1080i or 1080p
    16:9
    1920
    1080
    2160p
     Ultra High Definition (UHD) or 4K
    16:9
    3840
    2160
