This error happens when using a memory card that is not fast enough to record the data being saved by camera. An SDXC Memory Card of Class 10 or faster is required to record using the XAVC S format. An exFAT compatible memory card is required when recording XAVC S.
NOTE: The HDR-AS100 Action Cam will display an error message of MEDIA if attempting to record in XAVC S format without an SDXC Class 10 or higher memory card.
