How should I operate the Energy Saving Switch?
When the Energy Saving Switch is OFF, power consumption is reduced. This means the TV cannot be powered on.
The Energy Saving Switch and Power button are typically located at the lower right side of your TV, at the back. For details on your particular model, please refer to the Operations Instructions on our Support site (section Parts Description > TV Controls and indicators).
• [6] = Energy Saving Switch
When the Energy Saving Switch is switched OFF, power consumption is reduced. This means the TV cannot be powered on. To power on the TV, change the Energy Saving Switch to ON.
• [1] = Power button
Only when the Energy Saving Switch is ON, the TV can be turned on. Press the Power button to turn on the TV.
NOTE: If the TV is in Standby mode (red LED on), the TV will turn OFF pressing the Power button once. Pressing a second time, the TV will turn ON.
