How to troubleshoot battery problems
Batteries are consumables, which means they are expected to require periodic replacement during the lifetime of a computer. For information about guarantee conditions for your battery, please consult the Regulations, Guarantee, EULA and Service Support booklet.
If your battery is worn, you can purchase a new battery for your VAIO at the Sonystyle store, or a local dealer locator.
In case batteries for your VAIO model are not available anymore in retail, you may still be able to purchase a battery as service part. Contact our services to check for prices and availability.
You may be confronted with one of below battery issues. Click the applicable link for the recommended Sony solution.
Battery looses charge when the VAIO is switched offVAIO notebooks may consume a small amount of energy from the battery even when completely switched off. This behaviour is by design and cannot be changed. Note: the boot process is quite power-intensive and may consume a considerable amount of battery charge. VAIO does not function anymore on battery or does not charge anymore
VAIO shows an error message stating that your battery is not an original Sony batteryWARNING: Third party batteries may not be designed according to the security guidelines, and may therefore be more susceptible to overheating. If you have recently purchased a new battery for your VAIO, and this message shows up, we recommend to return it to your dealer. In rare conditions, this message may appear with an original Sony battery.
