Article ID : 00091587 / Last Modified : 15/12/2015Print
The camera takes multiple pictures when pressing the shutter button.
    Depending on your camera, you may have a setting selected that allows multi image capture.
    Here are some scenarios when multi image capture is used:
    • The camera is set to shoot with Superior Auto.
    • Drive Mode is set to settings other than Single Shooting and Self-timer.
    • ISO is set to Multi Frame NR.
    • DRO/Auto HDR is set to Auto HDR.
    • Picture Effect is set to HDR Painting or Rich-tone Mono..
    • Scene Selection is set to Hand-held Twilight or Anti Motion Blur.
    Make sure none of the settings above are selected if you do not want to shoot multiple images.
