Article ID : 00076911 / Last Modified : 11/08/2020Print
    How to transfer videos and images wirelessly to a smartphone.
    IMPORTANT:
    • The ADP-WL1M wireless adapter and PlayMemories Mobile app is required.
    • The PlayMemories Mobile app must be installed on your mobile device. For details, refer to the PlayMemories Mobile support page:
    https://www.sony.net/pmm/
    1. On the camcorder, press the PLAY button.
    2. On the camcorder LCD screen, touch MENU.
    3. Touch EDIT/COPY.
    4. Touch Send to Smartphone.
    5. Touch Select on this device.
    6. Touch to select the type or content you want to transfer: MOVIE or PHOTO.
    7. Touch to select the content you want to transfer.
      NOTE: A checkmark is added next to each image you select.
    8. Touch OK.
      NOTE: The SSID and PASSWORD display on the camcorder LCD screen.
    9. On your smartphone, open the PlayMemories Mobile app.
    10. In the PlayMemories Mobile app, select the SSID of the camcorder.
    11. Type in the camcorder password.
      NOTE: A connection is established between the smartphone and camcorder.
    12. Select Copy.
