Article ID : 00065808 / Last Modified : 25/05/2022
Is it necessary to pair with each connection?
    IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
    When connecting Bluetooth devices for the first time, mutual registration is required. This is called pairing. Pairing is required only when connecting the two devices for the first time as the devices should recognise each other automatically on subsequent connections.
    You will have to complete the pairing process again if the pairing information is deleted or corrupted. This can happen under the following circumstances:
    If a device you have already paired cannot be connected, pair the device again.
