Article ID : 00059035 / Last Modified : 14/09/2020
What is the difference between the LA-EA1, LA-EA2, LA-EA3, and LA-EA4 lens mount adapters?
    Refer to the table below for differences between the lens mount adapters.
    About compatibility between the cameras and lenses, refer to the following Website:
    https://support.d-imaging.sony.co.jp/www/cscs/lens_body/index.php
    Function/Operation
    LA-EA1
    LA-EA2
    LA-EA3
    LA-EA4
    Auto focus (AF) Only available with SAM/SSM lenses  Available for all lenses Only available with SAM/SSM lenses  Available for all lenses
    AF system Contrast AF Phase-detection AF Contrast AF Phase-detection AF
    Format Supports APS-C sensor Supports APS-C sensor Supports 35mm Full-frame sensor Supports 35mm Full-frame sensor
    NOTES:
    • Because the LA-EA3 and LA-EA4 support 35mm full-frame sensors, the light passage on these adapters is larger than the LA-EA1 and LA-EA2, which causes vignetting.
    • If you are using the NEX-3, C3, 5 or the NEX-VG10, a firmware update for the lens and/or the adapter is required.
