Article ID : 00103241 / Last Modified : 30/03/2021
How do I prevent dust, dirt or moisture from getting inside the camera?
    Since DSLR, SLT, NEX, ILCE and ILCA cameras use interchangeable lenses, there is always the possibility that a piece of dust, spec of dirt or moisture may find its way inside your camera and ultimately onto the image sensor (or mirror) when changing lenses. There are precautions, however, to help avoid this situation.
    NOTE: DSLR, SLT and ILCA cameras have mirrors, while NEX and ILCE cameras do not.
    • Turn off the camera before changing the lens - image sensors can have an electric charge that attracts dust.
    • Only change lenses in a clean environment, preferably indoors away from any fans, vents or windows.
    • Check the lens before attaching it to the camera; if dust is found on the lens a blower can be used to remove it.
    • Have the lens you want to attach ready beforehand so the lens opening of the camera is exposed for as little time as possible.
    • Position the camera downward when removing and attaching a lens to prevent dust or dirt from falling into the lens opening.
    • Attach a dust cap to the front of the camera after removing the lens if not using the camera for a prolonged amount of time.
    • Attach a dust cap to the lens you removed from the camera.
    As stated previously, there is still a chance of dust, dirt or moisture finding its way inside a camera with interchangeable lenses. Moisture may still accumulate if the air inside the camera is dry and the air in the outside environment is moist. Following the guidelines above, however, should help minimize these circumstances.
    Cleaning the image sensor for DSLR, SLT and ILCA cameras:
    How should I clean the mirror and image sensor?
    Cleaning the image sensor for NEX and ILCE cameras:
    How to clean the body, lens and image sensor for ILCE and NEX cameras
