Article ID : 00159704 / Last Modified : 29/09/2016Print
An Image Database File Error occurs.
    This error message will appear if some of the image database files for movies have somehow become corrupt. It can occur if the movies on the memory card were modified or edited on a computer, causing inconsistencies in the data. You can try resolving the issue by selecting the Recover Image DB option.
    WARNING: There is a risk of data loss. The following information requires the memory card to be formatted. Make sure all picture and movie files are backed up on a computer before proceeding.
    If the issue continues to occur even after recovering the image database file, back up all the pictures and movies to a computer, then format the card. If the error continues after attempting to use the newly-formatted memory card, use a different memory card.
