How to set the Parental Control for Internet Video?
Follow the procedure below to configure the Parental Control settings:
- Select Internet Video Parental Control in Parental Control settings.
- Press ENTER.
- Enter your four-digit password using the up or down buttons or the number buttons.
- Select OK.
- Press ENTER.
- Select the restriction level.
- Press ENTER.
NOTE: The initial restriction level is No Restrictions. It is necessary to set the four-digit password in advance.
