Article ID : 00060187 / Last Modified : 11/12/2013Print
Can the E-mount lenses be used with other cameras?
    The E-mount lenses are only designed for cameras that have an E-mount frame. Use with other cameras is not supported or guaranteed.
    NOTE: APS-C sized E-mount lenses will record APS-C sized images even when attached to a full-frame camera.
