Article ID : 00070121 / Last Modified : 18/08/2026Print
    How to troubleshoot camera battery charging issues
    If your camera battery won't charge, refer to the Troubleshooting Steps section of this page. If the issue continues, we recommend purchasing a new battery for your camera. To find out which batteries are compatible with your camera, visit the Accessories Compatibility Information website.
    Camera Battery Types
    Sony batteries have a letter written on the top to indicate the battery type name.
    • For D, G, K, N, R, T, and X batteries:
      Image showing the letter on the top of the Sony X battery.
    • For H, M, V, W, and Z batteries:
      Image showing the letter on the top of the Sony Z battery.
    • For SA battery:
      Image showing the letter on the top of the Sony SA battery.
    Step 1. Check if the battery is inserted in the right direction.
    As shown in the image below, insert the battery pack while pressing the lock lever (A) with the tip of the battery until the battery locks into place.
    Note: The image is an example only. For details on inserting the battery, refer to the camera instruction manual.
    • Example of an X battery type:
      Image showing the position of the Sony X battery lock lever (A) and the direction to insert the battery.
    • Example of a Z battery type:
      Image showing the position of the Sony Z battery lock lever (A) and the direction to insert the battery.
    Step 2. Check the status of the charging light and battery terminals.
    If the CHARGE/Charge lamp flashes or does not light up, the terminal may be dirty or there may be an issue with the battery. Wipe any dirt or fingerprints from the terminal with a dry cloth, then charge the battery again.
    Note: Do not touch the battery terminal with your hands or any metal objects.
    Enlarged image of a Sony battery terminal (X and N) and examples of different terminal conditions.
    • A: This is an example of a clean battery terminal.
    • B: This is an example of fingerprints on the terminal.
    • C: This is an example of objects (or other materials) stuck to the terminal.
    Charging Requirements
    • Use Sony-exclusive products for the battery, AC adapter, USB cable, and battery charger. If you use a third-party product, charging may not be carried out properly or may cause a malfunction.
    • If your camera did not include an AC adapter or USB cable, use a commercially available AC adapter and USB cable.
    • For cameras that support USB PD (USB Power Delivery), you can enable fast charging by using a commercially available USB PD-compatible device.
      USB PD compatibility and the required output vary depending on your camera model. For details, please check:
      Which Sony cameras support USB PD (USB Power Delivery)?
      Note: Some commercially available USB AC adapters have their own charging standards and may not be able to charge the battery installed in the camera. (For example, the camera charging lamp lights up for approximately 20 seconds before turning off, and the battery does not charge.) We recommend using a device that supports USB PD (USB Power Delivery).
    • For cameras that do not support USB PD, please use a USB AC adapter with a rated output current of 1.5A or higher.
    • For some cameras with both a Multi/Micro USB terminal and a USB Type-C® terminal, charging via the Multi/Micro USB terminal is not possible. Please use the USB Type-C terminal.
    Notes:
    • The CHARGE/Charge lamp may flash if you charge a battery that has not been charged for a long time or has an extremely low charge level (e.g., immediately after purchase). In this case, remove the battery and charge it again to resolve the issue.
    • Try to recharge the battery in an appropriate environment. You may not be able to charge normally in the following situations:
      • The camera temperature is high after a long video shoot.
      • The ambient temperature is outside the range of 10°C to 30°C (50°F to 86°F).
    Charging Methods
    Check the links below for more details on how to charge using different charging methods.
    Note: Depending on the model, the charging method or accessories may differ. For details on the charging method, refer to your camera manual.
