Sony announces a 4K 60p pan-tilt-zoom camera with AI-based Auto Framing ​
 ​ Seamlessly integrating with Sony’s ecosystem, the BRC-AM7 also features proven image quality and an integrated lens
PARAMUS, NJ – Apr. 10, 2024 – Sony is releasing a flagship 4K 60p pan-tilt-zoom (PTZ) camera model with an integrated lens, the BRC-AM7. Incorporating PTZ Auto Framing technology, which uses AI technology for advanced recognition, the camera facilitates accurate and natural automatic tracking of moving subjects. These innovations enable simplified high-quality video production for broadcast, live event, and sports productions. ​
The BRC-AM7 is also the world's smallest and lightest integrated lens PTZ camera[1], measuring 168.7mm in width (approximately 6.64 inches), 225.2mm in height (roughly 8.87 inches), and 192.3mm in depth (about 7.57 inches), with a weight of only 3.7kg (approximately 8.16 pounds). The size and weight promote greater freedom including increased installation flexibility, broader accessibility in challenging locations, and more vantage points. The BRC-AM7 also works effortlessly alongside Sony’s professional camera ecosystem, providing compatibility and seamless color matching. ​
“The BRC-AM7 enhances Sony’s rich legacy of PTZ cameras renowned for their image quality and reinforces Sony’s connected ecosystem of solutions,” said Norbert Paquet, Head of Live Production, Sony Europe. “We recently incorporated AI-based auto tracking technology into our models and the feedback was tremendous. The camera’s ability to consistently track and frame talent will provide production efficiencies by taking time and guess work out of creating content while providing high production values.”
The BRC-AM7 is planned to be available in early 2025. It is scheduled to be on display in Sony’s booth (C8201) at the National Associations of Broadcasters (NAB) Show 2024 in Las Vegas, Apr. 14-17, 2024.
Sony’s advanced PTZ Auto Framing technology, which is currently featured in the SRG-A series of PTZ cameras optimized for corporate and education customers, will expand to additional models. Planned for spring 2025 or later,, Sony will provide a Ver. 3.00 firmware update that will add the PTZ Auto Framing technology to the FR7 full-frame, interchangeable lens PTZ camera.
Excellent Picture Quality
By combining the 1.0-type 4K compatible stacked Exmor RS™ CMOS image sensor and the latest image processing engine BIONZ XR®, the BRC-AM7 achieves 4K 60p high resolution imagery with less noise. 5K oversampling allows users to capture high-resolution 4K video, and it also supports 4K HDR imagery, which clearly depicts both bright and dark scenes.
The newly developed all-in-one lens is equipped with a 20x optical zoom and Clear Image Zoom, an all-pixel super-resolution zoom that allows high magnification zooming while maintaining resolution, providing telephoto capture up to 30x in 4K or 40x in Full HD.
It also has a built-in unique electronic variable ND filter that allows for seamlessly adjusting the filter transmittance from 1/4 to 1/128. In addition to being able to adjust the exposure without changing the depth of field, users can also take advantage of auto settings to automatically adjust the light intensity to the level set on the camera to accommodate environments with challenging lighting conditions.
Advanced PTZ Auto Framing Technology
Sony’s PTZ Auto Framing technology, which also incorporates auto focus, employs built-in AI analytics for advanced recognition, automatically tracking a subject based on detailed information such as the person's skeleton, head, face, and clothing. The intuitive operation and remote capabilities help create efficiencies in managing a production or live event.
The newly developed pan-tilt rotation mechanism enables quick, smooth, and quiet operation at a speed of 0.004 degrees per second up to 180 degrees per second. It expands the range of applications, to include scenarios requiring accurate framing movement, such as dance, concerts, faith services and sports. Furthermore, the BRC-AM7 is equipped with a pre-set function that allows the camera composition to be registered and recalled for effortless reproduction.
Robust System Interoperability
The BRC-AM7 easily integrates into Sony’s camera lineup, employing "ITU709," "709tone," "S-Cinetone™," and "S-Log3" compatibility for simplified color matching. It also features a familiar user experience and operation. The camera supports GENLOCK terminals and is compatible with Sony’s Master Setup Units and Remote-Control Panels, enabling multi-camera operation, as well as integration with Sony’s switchers. ​
Additionally, the camera’s compact and lightweight design allows for capture in difficult-to-install locations including on ceilings, cranes, or batons on stage, as well as tripod shooting using the 3/8-16 UNC and 1/4-20 UNC screw holes on the bottom surface.
In terms of power supply, the BRC-AM7 is compatible with the versatile XLR 4-pin connector and supports PoE++ (Power over Ethernet Plus Plus)[2]. ​
Versatile audio inputs and video outputs allow for increased system expansion and customization. The camera features 12G-SDI and HDMI® outputs, and 3G-SDI for monitor output. For audio, the BRC-AM7 has two channels of XLR 3-pin connectors and a φ3.5mm stereo input. ​
IP and free-d Compatible for Supporting New Video Production
The BRC-AM7 supports SRT, RTMP, RTSP, NDI[3], and optical fiber, enabling remote production over IP networks. It is compatible with VISCA™ over IP, S700PTP protocol, and CGI, allowing for remote camera control via external commands. It also supports IP Tally, providing comprehensive support for remote production.
Furthermore, the BRC-AM7 is compatible with the free-d protocol, which is commonly used in virtual productions such as augmented reality (AR) and virtual reality (VR). It can accurately output camera tracking information (pan/tilt/zoom/focus/iris) into a 3D space, allowing for seamless integration of live footage of real people with 3D Computer Graphics backgrounds and characters, creating realistic composite images.
Sustainable Construction and Packaging
Elements of the BRC-AM7 incorporate sustainable materials including SORPLAS™ recycled plastic and more environmentally conscious packaging.
For more information about Sony’s presence at the NAB Show, please visit https://pro.sony/nab. For the latest media and entertainment-related news and updates from Sony, visit https://pro.sony/press or follow Sony Professional on social media: LinkedIn, Twitter, Facebook, Instagram, YouTube. ​
1 Equipped with a 1.0-inch type image sensor and compatible with 4K60P as an integrated lens PTZ remote camera. As of April 2024, announcement. According to Sony research.
2 Compliant with IEEE802.3bt (Type 4 Class 8).
3 NDI is a registered trademark of the Vizrt Group.
About Sony Corporation
Sony Corporation is a wholly owned subsidiary of Sony Group Corporation and is responsible for the Entertainment, Technology & Services (ET&S) business. With the vision of "continuing to deliver Kando and Anshin (*) to people and society across the world through the pursuit of technology and new challenges," Sony Corporation supports the Sony Group with technology to create the entertainment of the future together with creators.
For more information, visit: pro.sony.eu
* Both Japanese words, Kando means emotion and Anshin has various meanings such as peace of mind, reassurance, reliability, and trust.
