Article ID : 00203010 / Last Modified : 27/06/2019
Initial settings of Google Assistant on your wireless headphones
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product or consult the help guide on your product page.
Preparations
  • Headphones that currently support Google Assistant
      Supported models:
  • Download the Headphones Connect app(software version 3.1.0 or later)
      For Android
      For iOS
  • Smartphones that support Google Assistant app (The Google app must be updated to the latest version)
      For Android (Version 5.0 or later)
      For iOS (Version 10.0 or later)
When using Google Assistant for the first time, you will have to change the function of the NC/AMBIENT button and configure the initial settings for Google Assistant.
  1. Start the Headphones Connect app and connect your wireless headphone.
  2. Change the function of the NC/AMBIENT button to Google Assistant.
    Select Change the function of the NC/AMBIENT button and select Google Assistant.
    NC Ambient button screenshot
  3. Configure the initial settings of Google Assistant.
  • For Android devices
    Press and hold the smartphone's home button to start the Google Assistant app.
    Tap Finish the headphones setup and follow the displayed instructions to complete the setup.
    Finish Google Assistant setup screenshot
  • For iOS devices
    Start the Google Assistant app.
    Finish iOS Google Assistant setup
