Article ID : 00202991 / Last Modified : 27/06/2019
Using Google Assistant with wireless headphones
Google Assistant assists you in operating your headphones using only your voice. It allows you to listen to music, contact your friends, set reminders, and more, without the need of operating your smartphone.
If your software version is before 2.0.0, please update your software.
What can Google Assistant do?
Google Assistant functions & commands
Google Assistant settings
Initial settings for Google Assistant.
Initial Settings Google Assistant
Calling Google Assistant
How to operate Google Assistant using the NC/AMBIENT button of your headphones
