Article ID : 00203037 / Last Modified : 27/06/2019
How to configure the Google Assistant music app
    Preparation
    Some settings must be configured in order to use Google Assistant.
    For details other than how to configure the music app settings, check the following pages as well.
    How to configure music app settings
    The app used to play music can be changed on the Google Assistant setting screen.
    For Android device
    1. Press and hold the smartphone's home button to start the Google Assistant app.
      Ensure that the Google Assistant function is active.
    2. Tap the compass icon on the upper right of the screen.
      compass icon on Google Assistant app
    3. Tap the three vertically aligned dots  on the upper right of the Usage and Hint screen and then tap Settings.
      How to access settings
    4. Scroll down and tap Music.
      Selecting Music - Google Assistant
    5. Select the music app.
      Selecting music app
    For iOS device
    1. Start the Google Assistant app on the smartphone.
    2. Tapon the upper right of the screen.
      Going to music settings iOS
    3. Settings.
      Selecting settings
      Selecting music
      Choose the music app
