Article ID : 00203028 / Last Modified : 27/06/2019
How to enable the Google Assistant Spoken Notifications setting
    Some settings must be configured to use Google Assistant.
    For details other than how to configure the Spoken notifications settings, check the following pages as well.
    How to configure the Spoken notifications settings
    The read-out setting for Spoken notifications can be set ON/OFF using the Google Assistant app.
     For Android devices
    1. Press and hold the smartphone's home button to start the Google Assistant app.
      Ensure that the Google Assistant function is active and usable.
    2. Tap Headphone settings.
      Headphones setting Android screen
    3. On the Assistant Setting screen, tap Spoken notifications.
      Google Assistant spoken notification setting
    4. Change the setting on the Spoken Notifications screen.
      Settings change Android
    For iOS devices
    1. Start the Google Assistant app on the smartphone.
    2. Tapon the upper right of the screen.
      iOS Settings Google Assistant
    3. Tap Settings.
      Settings
    4. Tap the headphone model name in the Devices section of the settings screen.
      Device selection
    5. Change the setting on the Spoken Notifications screen.
      Enabling Spoken notifications
