Article ID : 00202991 / Last Modified : 14/10/2020
Using Google Assistant with wireless headphones
    Google Assistant assists you in operating your headphones using only your voice without the need of operating your smartphone and lets you perform operations when listening to music, contact your friends, set reminders, and more.
    What do I need?
    • Headphones that support Google Assistant
      • To check if your headphones support Google Assistant, see the Applicable Products and Categories section of This Article.
      • Update the headphones software to the latest version. Visit the Sony Support website, search for your headphones by entering the model number, and then go to the Downloads section for more information.
    • Download the Sony | Headphones Connect app
      Install the latest version of the Headphones Connect app:
    • A smartphone that supports Google Assistant app
      Download and install the latest version of Google Assistant.
    What can Google Assistant do?
    Google Assistant functions & commands
    Google Assistant settings
    Initial settings for Google Assistant.
    Initial Settings Google Assistant
    Calling Google Assistant
    How to operate Google Assistant using the NC/AMBIENT button of your headphones
