Headphones Self-Help Center
Please select the topic that is closest to the issue that you are currently having to perform step-by-step troubleshooting.
If you are facing an issue that is not listed below, you may try to reset/initialize your headphones by referring to How to reset or initialize the Wireless Headphones.
Alternatively, please enter your query in the search bar on the main Sony support website.
Hints:- Learn how to improve your headphones durability, or connectivity to other devices with our Getting Started with Sony Bluetooth Headphones guide.
- For WF-1000XM4: If you encounter the touch sensor working unexpectedly, please refer to The touch sensor works unexpectedly even though I don't touch it.
No Power
Battery issues
Bluetooth pairing issues
No Sound, or Sound is only heard from one side
Audio
(imbalanced sound, volume adjustment, skipping sound, noise)
Noise Canceling is insufficient
Microphone Issues during phone call
(Inaudible voice or background noise)
Physical Damage or missing parts
For information on warranty, please select your country / area from Warranty Information page
