Article ID : 00285172 / Last Modified : 31/10/2022Print
How to reset or initialize the Wireless Headphones
    Notes:
    • The reset method differs depending on the product. If your model is not listed below, kindly refer to your product manual.
    • The settings return to their initial status after initialization. Settings such as language of the voice guidance will also return to the factory setting.
    Select the appropriate headphones type or model for resetting steps:
    Headband
    Truly Wireless
