Article ID : 00202807 / Last Modified : 18/01/2019
macOS Mojave(10.14) Compatibility Information for Application Software
IMPORTANT: Operation is not guaranteed for all computers.
Application SoftwareVersionApplicable Product CategoriesmacOS 10.14
(Mojave)
Notes
Imaging Edge (Remote/Viewer/Edit)
*64-bit only
1.3.00Cyber-shot
α (Alpha)
Under Evaluation
PlayMemories Home3.6.01Handycam
Cyber-shot
α (Alpha)
Action Cam
Bloggie / Webbie
Digital Recording Binoculars
Under EvaluationWe have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution.
Image Data Converter
Handycam
Cyber-shot
α (Alpha)
Not Support
Downloading of Image Data Converter has been discontinued since September 2018.
Please use Imaging Edge (Remote/Viewer/Edit) from now on.
Remote Camera Control-Cyber-shot
α (Alpha)
Not SupportDownloading of Remote Camera Control has been discontinued since September 2018.
Action Cam Movie Creator3.6.01Action CamUnder EvaluationWe have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution.
MVR Studio1.0.03 or laterMusic Video RecorderCompatible
IPTC Metadata Preset1.1.00α9 (ILCE-9)Under Evaluation
PlayMemories Camera Apps-Cyber-shot
α (Alpha)
Not CompatibleWe have found the issue that the applications cannot be downloaded from the PlayMemories Camera Apps site by neither Safari 12 nor macOS Mojave, and investigations are in progress. Please use the Wi-Fi function of your camera.
