Article ID : 00247119 / Last Modified : 26/06/2022Print
Gaming Console - Component
    Making a Connection
    Connect the video (Y/Pb/Pr) and audio (red and white) pins of the component cable to COMPONENT IN on the TV. Connect the other end of the component cable to the Gaming console.
    Image of connecting TV and Gaming Console with component cable
    1. Gaming console
    2. Component cable
    3. TV: COMPONENT IN
    If your TV does not have a component terminal and your Gaming console also supports composite cables, try connecting with a composite cable.
    Refer to: Gaming Console – Composite
    TV Set-up
    1. After making a connection, turn on your TV.
    2. Press the (Input) button repeatedly to select the input to the connected Gaming console.
      image of remote control
    3. Turn on your Gaming console by pressing the power button.
