Article ID : 00112546 / Last Modified : 07/08/2018
How do I install apps on my Sony's Android TV?
    You can check what apps can be installed on Sony's Android TV from the Google Play Store. Here's how to tell the difference between an Android and non-Android TV.
    If you wish to install apps on your Sony's Android TV, start by going to the Home menu, by pressing the HOME button on your remote control
    1. Then, scroll down to the Apps shelf and select the Store - Google Play icon
    2. You will then be taken to Google's applications store: Google Play, where you can browse for applications, and download and install them on your TV.
    Remote control Home button
    GooglePlay icon
    NOTES:
    • The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version.
    • Google Play on the TV only displays apps that are supported by the TV, so apps that are not displayed are not supported at the moment.
    • Bravia Smart TV's are only able to run the catch-up/on-demand apps that are made explicitly available for these models through the Sony's Internet Contents. That's why you cannot install 3rd-party apps from other sources (e.g Google Play store) on Sony televisions that are not Sony Android TVs.
    • What apps are available on Sony's Android TV?
