Article ID : 00227351 / Last Modified : 27/06/2019
My TV doesn't respond when I say "Ok Google"
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article.
    • Check the TV position setting.
      1. Press the HOME button on the TV remote control.
      2. Select  Settings.
      3. Select Sound or select Display & Sound and then select Sound.
      4. Select TV position.
      5. Select Table-Top stand or Wall Mount.
    • Say "Ok Google" clearly and louder than the TV sound.
    NOTE: If the room is too noisy, move closer to your TV or use the MIC button on the TV remote control.
