Article ID : 00200540 / Last Modified : 27/06/2019
The Amazon Alexa compatible speaker can't find Sony's Android TV
    IMPORTANT: This article only applies to a specific country, products and/or operating systems. Please check the Applicable Products and Categories section of this article.
    Check the following.
    1. Check that device discovery is performed on an Amazon Alexa compatible speaker such as Amazon Echo.
    2. Check whether the TV name is displayed in the Amazon Alexa app.
      NOTE: The Amazon Alexa app is a mobile application provided by Amazon.
      • If the TV name is not displayed in the Amazon Alexa app:
        Perform device discovery again with the TV Control Setup with Amazon Alexa app on the TV.
      • If the TV name is displayed in the Amazon Alexa app:
        The Amazon Alexa compatible speaker may not be able to recognise the TV name correctly. Change the TV name from the TV Control Setup with Amazon Alexa app on the TV. There are two ways to change it.
        • Select the TV name from the list displayed in the TV Control Setup with Amazon Alexa app.
        • When setting your desired TV name, use a simple name that Alexa can easily recognise and in the same language set in the Amazon Alexa app (the language used to speak with Alexa).
        • After changing the TV name, perform device discovery.
