What types resolution and subsampling are supported by the TV?
Depending on the TV that you use, the supported types of video signals will be different.
Resolution/ frequency | 8bit | 10bit | 12bit |
3840@24Hz 3840@25Hz 3840@30Hz 4096@24Hz 4096@25Hz 4096@30Hz | YCbCr 4:2:2 YCbCr 4:4:4 RGB | YCbCr 4:2:2 YCbCr 4:4:4 * RGB * | YCbCr 4:2:2 YCbCr 4:4:4 * RGB * |
3840@50Hz 3840@60Hz 4096@50Hz 4096@60Hz | YCbCr 4:2:0 YCbCr 4:2:2 * YCbCr 4:4:4 * RGB * | YCbCr 4:2:0 * YCbCr 4:2:2 * YCbCr 4:4:4 *2*3 RGB *2*3 | YCbCr 4:2:0 * YCbCr 4:2:2 * YCbCr 4:4:4 *2*3 RGB *2*3 |
3840@100Hz 3840@120Hz | YCbCr 4:2:0 *2*3 YCbCr 4:2:2 *2*3 YCbCr 4:4:4 *2*3 RGB *2*3 | YCbCr 4:2:0 *2*3 YCbCr 4:2:2 *2*3 YCbCr 4:4:4 *2*3 RGB *2*3 | YCbCr 4:2:0 *2*3 YCbCr 4:2:2 *2*3 YCbCr 4:4:4 *2 RGB *2 |
7680@24Hz 7680@25Hz 7680@30Hz | YCbCr 4:2:0 *3 YCbCr 4:2:2 *3 YCbCr 4:4:4 *3 RGB *3 | YCbCr 4:2:0 *3 YCbCr 4:2:2 *3 YCbCr 4:4:4 *3 RGB *3 | YCbCr 4:2:0 *3 YCbCr 4:2:2 *3 - - |
7680@50Hz 7680@60Hz | YCbCr 4:2:0 *3 - - - | YCbCr 4:2:0 *3 - - - | - - - - |
*: Enhanced format (Dolby Vision) or Enhanced format (3Gbps~6Gbps)
*2: Only for HDMI IN 2 or HDMI IN 3 terminal: Enhanced format (6Gbps~12Gbps)
*3: Only for HDMI IN 4 terminal: Enhanced format (4K120, 8K) (6Gbps~10Gbps)
NOTE: The connected HDMI cable and the HDMI signal format settings will differ depending on the input signal. For details, refer to the How do I view 4K (50/60p or 100/120p) and HDR content from an external HDMI device connected to an Android TV™/Google TV? article.
For 2021 Google TV models (except for Z9J)
3840@50Hz 3840@60Hz 4096@50Hz 4096@60Hz | YCbCr 4:2:0 YCbCr 4:2:2 * YCbCr 4:4:4 * RGB * | YCbCr 4:2:0 * YCbCr 4:2:2 * YCbCr 4:4:4 *2 RGB *2 | YCbCr 4:2:0 * YCbCr 4:2:2 * YCbCr 4:4:4 *2 RGB *2 |
3840@100Hz 3840@120Hz | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 |
*2: Only A80J_A83J_A84J, A90J, X85J_X86J_X89J, X90J_X91J_X92J_X93J_X94J (50-75, 100), X91J (85), X95J, KM-X85J, XRM-A80J, XRM-A90J, XRM-X90J and XRM-X95J series (HDMI IN 3 or HDMI IN 4 terminal): Enhanced format (6Gbps~12Gbps)
NOTE: The connected HDMI cable and the HDMI signal format settings will differ depending on the input signal. For details, refer to the How do I view 4K (50/60p or 100/120p) and HDR content from an external HDMI device connected to an Android TV/Google TV? article.
YCbCr 4:2:0 *2 | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 |
YCbCr 4:2:0 *2 |
7680@24Hz 7680@25Hz 7680@30Hz | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 YCbCr 4:4:4 *2 RGB *2 | YCbCr 4:2:0 *2 YCbCr 4:2:2 *2 - - |
7680@50Hz 7680@60Hz | YCbCr 4:2:0 *2 - - - | YCbCr 4:2:0 *2 - - - | - - - - |
- *: Enhanced format (Dolby Vision) (3Gbps~6Gbps)
- *2: Only for HDMI IN 4 terminal: Enhanced format (8K) (6Gbps~10Gbps)
- The connected HDMI cable and the HDMI signal format settings will differ depending on the input signal. For more details, refer to the How do I view 4K (50/60p or 100/120p) and HDR content from an external HDMI device connected to an Android TV™? article.
YCbCr 4:2:0 *2 |
- *2: Only XH9 and XH92 series (HDMI IN 3 or HDMI IN 4 terminal): Enhanced format (6Gbps~12Gbps)
- The XH90 and XH92 series will need a software update. For details on how to update your TV, refer to the How do I perform Firmware/ Software Updates for my Android TV? article.
- The connected HDMI cable and the HDMI signal format settings will differ depending on the input signal. For details, refer to the How do I view 4K (50/60p or 100/120p) and HDR content from an external HDMI device connected to an Android TV? article.
For an Android TV other than the above
3840@50Hz 3840@60Hz 4096@50Hz 4096@60Hz | YCbCr 4:2:0 YCbCr 4:2:2 * YCbCr 4:4:4 * RGB * | YCbCr 4:2:0 * YCbCr 4:2:2 * - - | - YCbCr 4:2:2 * - - |
- *: Enhanced format (3Gbps~6Gbps), For 2015 models: please update your TV software to the latest version.
3840@24Hz 3840@25Hz 3840@30Hz 4096@24Hz 4096@25Hz 4096@30Hz | YCbCr 4:2:2 YCbCr 4:4:4 RGB | YCbCr 4:2:2 | YCbCr 4:2:2 |
3840@50Hz 3840@60Hz 4096@50Hz 4096@60Hz | YCbCr 4:2:0 | - | - |
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
