Article ID : 00146558 / Last Modified : 07/08/2020
How to set up and use the Wi-Fi Direct feature for 2014 TV models
    To set up and use the Wi-Fi Direct feature, follow the steps below.
    1. Enable the Built-in Wi-Fi setting on your TV.
      1. On the supplied remote control, press the HOME button.
      2. Select Settings.
        NOTE: The image below is an example of the 2014 TV model.
      3. Select System Settings or Network.
        NOTE: If the TV shows Network, skip to step 6.
      4. Select Setup.
      5. Select Wi-Fi Setup.
      6. Select Built-in Wi-Fi or Built-in Wireless LAN.
      7. Select ON.
    2. Turn on the Wi-Fi Direct setting of the TV.
      2. Select Settings.
      4. Select Setup.
      6. Select Wi-Fi Direct.
      7. Select ON.
    3. Display the WPA key of the TV.
      2. Select Settings.
      4. Select Setup.
      6. Select Wi-Fi Direct Settings.
      7. Press the Options button.
      8. Select Manual.
      9. Select Other Method.
        NOTE: The SSID and the WPA key will be displayed on the TV screen.
      10. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA key displayed on the TV screen as the password.
      NOTE:
