Article ID : 00161803 / Last Modified : 29/11/2018
How to play back the content stored in a mobile device on the TV screen
    There are several ways to display the content of a mobile device on the TV screen. First, select if you have an Android TV or another type of Bravia TV.
    Android TVs
    Other TVs
    NOTE: To check whether your TV is an Android TV, refer to the following article:
    How to check if your BRAVIA TV is an Android TV
    Android TVs
    The functions that are available vary depending on whether the TV is connected to the Internet.
    If the TV is connected to the Internet
    • Chromecast built-in (Google Cast)
    Simply tap the Cast icon  to display videos such as YouTube or photos saved in apps on the TV screen.
    How do I use Chromecast built-in (Google Cast) on Sony's Android TV
    If the TV is not connected to the Internet
    • Wi-Fi Direct
    You can make a direct wireless connection between the TV and mobile device and send photos and videos to the TV.
    How to set up and use the Wi-Fi Direct feature of the TV with the mobile device
    NOTE: For other methods, refer to Compatibility and other functions.
    Other TVs
    Make a direct wireless connection between the TV and mobile device.
    Functions that are available vary depending on the OS of the mobile device.
    Android mobile device
    iOS mobile device
    Compatibility
    Functions
    Android TVOther TVs
    Android OSiOSAndroid OSiOS
    Chromecast built-in (Google Cast)--
    Screen mirroring✓*-✓*-
    Wi-Fi Direct✓*✓*
    Photo Sharing Plus✓*✓*✓*✓*
    USB--✓*-
    MHL/HDMI✓*✓*✓*✓*
    * May not be supported depending on the model. Refer to the manual or specifications of the TV.
    Other functions
    • Photo Sharing Plus
    You can make a direct wireless connection between the TV and mobile device, and share photos and videos or save shared content to another device.
    • USB connection
      You can make a USB connection between the TV and Android mobile device and share photos, videos, and music.
    • MHL/HDMI connection
      If the mobile device supports Mobile High-Definition Link (MHL)
      You can use an MHL cable to display the screen of the mobile device on the TV.
      How to connect an MHL device to a TV using an MHL cable
    If the mobile device supports Micro HDMI
    You can use an HDMI cable to display the screen of the mobile device on the TV.
    NOTES:
    • Not all TVs have an MHL input. If the TV supports MHL, at least one of the HDMI inputs on the TV will be labelled MHL.
    • Not all mobile devices support MHL or Micro HDMI. Check the specifications or the supplied manual.
