Article ID : 00198415 / Last Modified : 27/06/2019
How can I find my TV's specifications?
What kind of information are you looking for? Below you will find useful information related to your TV.
Specifications related to your TV:
Comparing TV specifications
Product highlights and consumer information
Basic information such as dimensions, weight, and power consumption
Basic information related to Picture and Sound
For basic specifications, please refer to Specifications on your product page.
NOTE: A Specifications page may not be available depending on your model. In such cases, please refer to the Reference Guide or Operating Instructions described in the next section.
Parts and Controls / Wall mounting
Please refer to the Reference Guide or Operating Instructions on your product page. For wall mounting, you can also refer to the Installation Information (Wall-Mount Bracket) if our official wall-mount bracket is compatible.
Information about compatibility with other devices
For basic information, please refer to Specifications on your product page.
In addition, an article is also available in our Questions & Answers regarding compatibility information. For example, you can check USB HDDs compatible with Sony’s TV in the article below:
Software or apps
  • Software (Sony's Android TV only)
    You can check the Operating System (OS) version of your TV on the HOME Menu.
    For more information on the OS version, please refer to:
  • Apps
    For Sony's Android TV
    • Checking all installed apps
      You can check all of the apps installed (including pre-installed) on your TV using the HOME Menu.
      1. Press the HOME button on the remote control.
      2. Select Settings.
      3. Select Apps in the TV category.
      4. Check Downloaded apps or System apps.
    • Checking apps available for installation
      You can check what apps can be installed on Sony's Android TV from the Google Play Store.
      There are two ways to check what apps can be installed on your TV.
      • Checking on the TV’s HOME Menu
      • Checking using a computer, tablet, or smartphone
For the details, please refer to:
For non-Android TV
You can check all of the apps on your TV on the HOME Menu.
For the details, refer to:
How to check or add apps to your TV (non-Android models)
Our product site can help you compare specifications between the latest models. For details, please refer to the article below:
Refer to Product Highlights on your product page.
NOTE:Product Highlights page may not be available depending on your model.
